some be my lift pump AND
Old Sep 6, 2012 | 06:47 PM
blacksally's Avatar
Default some be my lift pump AND
my truck starting acting up again code was for voltage outta range on the lift pump and no bus to pcm so i read up on the no bus which is probably the cluster and they have a recall for the rear cluster wirng connector which ill see if mine falls into it and try that before i buy a cluster and im probably gunna get a fass pump.
Old Sep 7, 2012 | 08:41 AM
RAW's Avatar
RAW
FASS is a good way to go, I have had zero problems with mine.
As for the codes, I hope the wiring connector is the fix, and you can get it for free. Otherwise, you could be chasing wires.
HeavyChevy95
Dec 21, 2016 10:36 PM
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
