1994 Fuel Sending Module
Old Sep 6, 2012 | 11:56 AM
dieseldog69's Avatar
Default 1994 Fuel Sending Module
1994 Ram 2500 12 valve- My fuel gauge quit working so I removed bed and pulled the old module out of tank to check out. Upon removing the module, I found the canister had broken away from the upper portion and was just sitting in tank. I bought a new OEM module yestrday and my question is this- Do I need to adjust the new module before installing? There are screws with enough clearance to let the module slide up and down. It also seems to be spring loaded, which may indicate the need to slide up or down????:
humm:
Old Sep 9, 2012 | 08:54 PM
hounddogks76's Avatar
From what i've gathered...the can is supposed to be able to slide up and down.
Old Sep 10, 2012 | 01:40 PM
Thanks- I went ahead and installed it without tightening the slide mechanism and everything is working perfect.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
