Need some help white smoking
Old Sep 5, 2012 | 10:33 PM
95Ky5.9's Avatar
Default Need some help white smoking
I installed a billet tappet cover roughly two weeks ago after reinstalling everything went to start but truck wouldn't start, retimed it and it started but smokes white at idle and pops if given any throttle and won't go over 1k have tried retiming a few times and have even taken pump off again to check everything but is still doing the same. Anyone have any thoughts or help?
:confused:
Old Sep 6, 2012 | 04:20 PM
cummin_un_glued's Avatar
FormerVendor
how are you timing it?
Old Sep 6, 2012 | 04:21 PM
biged681985's Avatar
It sounds like your timing is way off
Old Sep 6, 2012 | 05:06 PM
95Ky5.9's Avatar
I timed it using the blue point timing kit with the dial indicator, i was goin to pin time it but as luck would have it i dropped the pump gear nut in the timing cover
Old Sep 6, 2012 | 05:53 PM
FormerVendor
so now your taking the tin cover off to get the nut back? one thing that i have had problems with before is the timing jumping when i break the gear back loose after setting the plunger lift to what i want. any more i tighten the nut just enough to get the shaft to turn like 10ftlb maybe. also why dont ya walk us thru the steps just to make sure.
Old Sep 6, 2012 | 06:45 PM
95Ky5.9's Avatar
Yup and i usually break the nut loose before i go to set the plunger lift. But i take the intake horn and injector lines off
Take the dv holder and dv outta number 1 install the dial indicator take the oil fill off and break the pump gear nut loose, then have someone roll the engine over off the dampner til the needle bottoms out zero the dial indicator then turn the engine till the dial indicator is on the desired mm, pop the gear roll engine to tdc, reinstall washer and nut torque to 145 with someone holding the engine by the dampner to keep from spinning
Old Sep 6, 2012 | 06:52 PM
FormerVendor
which direction are you turning the engine?
Old Sep 6, 2012 | 07:42 PM
95Ky5.9's Avatar
Goin on with the rachet sooo clockwise
Old Sep 7, 2012 | 06:55 PM
FormerVendor
Ok...how much lift are you setting it at?
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old Sep 7, 2012 | 06:59 PM
95Ky5.9's Avatar
7-7.1mm 19 degrees on my 175 pump i had set it there awhile back and it ran real good
