Radiator question
Old Sep 5, 2012 | 02:37 PM
highfructosecornsyrp's Avatar
Default Radiator question
So I'm going to stick a 6.2 diesel into my range rover classic...
I am slowly coming to the conclusion that I will need to buy a custom aluminum 1" cored radiator. I only have 22"x20" of space. Thankfully I will have 6 inches or so of depth.
Here are my options, id like to hear what you guys think;
Aluminum radiator-$600
Stock radiator with high volume puller and two high volume pushers-free
Stock radiator with another stock radiator right behind it with puller and two pushers, a high output water pump-free
Stock radiator with another stock radiator mounted to the hood with hood louvers and two pusher fans sucking air through the hood a la , a puller and two pushers on the main radiator-free
The 600 dollar radiator is my fall back position...what do you guys think the best route would be? Dual radiator? Hood mounted? In line?
Old Sep 5, 2012 | 05:50 PM
Mayhem's Avatar
Have you tried looking for old Nova/Camaro radiators they are around the demensions you have and you can get them in 3 and 4 rows plus they are plumbed the wat a 6.2 is and are a common race car part I would check Summit or Jegs
Old Sep 5, 2012 | 06:21 PM
Thank you good sir. I found a three row aluminum one on eBay for two hundred bucks. I'm going to measure my total engine space when I get home. Very glad you posted that!
Old Sep 5, 2012 | 06:46 PM
Mayhem's Avatar
Np back in the day I was all about a Nova
Old Sep 5, 2012 | 08:00 PM
Turns out that is some great advice, thanks.
The rover radiator is 17.5x32.5 overall it appears. The nova 4 core aluminum says it is 19x27
The rover has several inches of fan shroud above the radiator so fitting a couple more inches of radiator up there to match it shouldn't be a problem.
Old Sep 5, 2012 | 08:03 PM
Mayhem's Avatar
Less money as well
