got a quick question guys
Old Sep 3, 2012 | 09:21 PM
dieselbomb87's Avatar
Default got a quick question guys
I have 05 dually 4x4 and when I hit 60 I am shooting about 2000 rpm. My axle ratio says 4.10 but anybody know how I can reduce the rpms?
Old Sep 3, 2012 | 09:26 PM
biged681985's Avatar
Bigger tires, gear vendor overdrive or swap gears
Old Sep 4, 2012 | 08:31 AM
Mdub707's Avatar
Yup, pretty much it. I'm running 35x12.5x17's with 3.73 gears, 2k rpm for me isn't til about 75mph. The larger tires actually helped my mileage, since I do a lot of highway driving.
Old Sep 4, 2012 | 09:50 AM
HeavyAssault's Avatar
+1 with Mdud....jump up the tire size to tame the RPMs. Low end may be affected somewhat but the drop in HWY rpms will make you happy. IIRC DRWs are a 17" wheel so look at Nitto Terras at 285/70/17.
Old Sep 4, 2012 | 09:58 AM
Mdub707's Avatar
The dually rims are REALLY narrow though aren't they? 285's would probably be ok, but anything larger might need different spacers. I think... haha
Old Sep 4, 2012 | 12:52 PM
I'm just curious how do bigger tires make a diff? If someone can explain please?
Old Sep 4, 2012 | 01:03 PM
A bigger tire will travel farther in one rotation than a smaller tire. I can't remember the math off top my head, but just throwing out numbers, a stock size tire will rotate 500 times in a mile. A tire two inches taller will rotate 475 times a mile. So by adding a bigger tire, u have just lowered your overall drive ratio, which lowers rpm.
Old Sep 4, 2012 | 01:11 PM
Mdub707's Avatar
It's just simple gearing calculations. Obviously going too big will offset the other way since it's a TON of rolling weight you'd be adding. Luckily we all drive diesel trucks that have enough power to turn these tires over with ease. Like GreenGoblin said, a taller tire will rotate less times in a fixed distance, thus lowering your cruising RPM's at a given speed.
Don't forget to get the speedo recalibrated so you can accurately measure your mileage. If the mileage is off, your MPG calculation will be off.
dutchsupreme
Diesel Engine Conversions
May 25, 2015 08:48 PM
May 8, 2015 11:10 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
12thman
Jan 20, 2015 03:22 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
