new 6.0 owner
Old Sep 2, 2012 | 10:23 AM
laspencer87's Avatar
Default new 6.0 owner
Hey every one, I have just bought my first diesel and it is a 2005 ford F-250 with the 6.0 what do i need to look out for. I have heard some bad things about the 6.0 and some good things please help thank you
Old Sep 2, 2012 | 12:48 PM
Karls03's Avatar
Without gauges, you're playing Russian Roulette with your truck. Whether you get a Scan Gauge II from Auto Zone, or an Edge CS/CTS monitor, you need to know what's going on with your truck. Both are going to require an EGT probe of some sort and a fuel psi is nice to have, not sure if Edge CS/CTS support fuel psi.
Anyway, what to look for:
1. Shutting down above 400* EGT (EGT Exhaust gas temp) can coke the oil in the turbom hence an EGT gauge.
2. Don't pound the throttle below operating temperature say 188*~195* range. You won't get max power from a cold engine, and it can lead to problems later.
3 Greater than 15* split between ECT and EOT at highway cruise (70mph) on flat ground can indicate a clogged oil cooler. (ECT engine coolant temp/EOT engine oil temp) A clogged oil cooler can lead to other problems.
4. PERSONALLY, a 5000 mile oil change interval is a waste of money. I did the factory 7500 for several years, and I have oil analysis reports to support my recent step to 10K. I DO NOT recommend this interval without an oil analysis.
These are my top things to look for. There are several threads about what mods work best, I recommend reading over the Performance section for that.
SCT or NOTHING for power programmers!
Old Sep 2, 2012 | 01:52 PM
thank you i have always wanted a diesel and do not want to mess any thing up
Old Sep 4, 2012 | 09:07 AM
Mdub707's Avatar
Just keep reading here, you'll learn soon enough.
texascwi
Jun 23, 2015 04:10 PM
slowstroke
For Sale
Apr 1, 2015 11:35 AM
scubasteve12
Mar 29, 2015 09:39 PM
Sophia'sJustice
Mar 5, 2015 04:06 PM
thumperf350
Jan 8, 2015 12:55 AM
