Best way to spend a few hundred bucks????
Old Sep 1, 2012 | 10:38 AM
THEGOLDPRO's Avatar
Default Best way to spend a few hundred bucks????
My truck is pretty much stock, I use it for towing my 18 foot landscape trailer 98% of the time, weigh's 7-8k loaded up. I wanna boost the hp alittle to help it pull up the hills. I don't want to start changing injectors and all that stuff, I just want a quick boost in power and call it a day.
My truck has the small Hy35 turbo on it, I was considering either swapping the bigger Hx35 OR slap a small tuner on there, which one would be a better option?? will i see any real noticible gains from the bigger turbo for towing or would a small tuner be a better option????
Old Sep 1, 2012 | 11:18 AM
biged681985's Avatar
A set of 100hp injectors is what I'd recommend. They don't get hot and will give a steady hp range at all rpm
Old Sep 1, 2012 | 01:22 PM
xzaq103's Avatar
FormerVendor
X2
Old Sep 1, 2012 | 01:31 PM
THEGOLDPRO's Avatar
How much power increases are we talking with just the injectors? Does 100hp mean 100 more hp over stock?
Old Sep 1, 2012 | 01:37 PM
In my 99 dodge, I put 150's in and laid down 320hp. So all together rwhp out of 150's was about 105. A set of 100hp injectors your lookin at probably 50-75 rwhp
Old Sep 1, 2012 | 01:38 PM
RAW's Avatar
RAW
With the proper amount of air, yes. They will also increase mileage, and increase driveability. I noticed a big difference with the 65HP injectors I had before.
If you can go over a few hundred, try and find a used Edge Juice with Attitude. It will increase power, mileage, give you gauges, and give you many other features.
Old Sep 1, 2012 | 01:41 PM
THEGOLDPRO's Avatar
Hmmm this is something to think about.
Maybe i could swap in some 100 hp injectors, then down the road ditch the hy35 and upgrade to the hx35.
Old Sep 1, 2012 | 06:40 PM
blacksally's Avatar
i got 150hp injectors and my truck will run hot even when the tune is on stock i wish id got the 100hp ones
Old Sep 1, 2012 | 07:47 PM
A stock 01 6 speed truck we put 100 hp injectors in, would hit bout 1350, plugged the waste gate and max get was around 1100 loaded with hay.
Old Sep 1, 2012 | 08:03 PM
cummin_un_glued's Avatar
FormerVendor
Like ed chris and ryan have said nothing better for the money then 100hp sticks
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
