BY pass fuel pump ideas?
Old Aug 31, 2012 | 01:58 PM
hugho's Avatar
Default BY pass fuel pump ideas?
Everyone knows the relative hassle switching out the fuel filters on the 94-98 trucks. Rather than buy Genos($$$$$!!) relocation kit my idea was to put a filter in front of the stock filter and I assume I would need a second(electric) pump to feed that new filter(eg one of the Baldwin 2 micron units?) because pumps work better pushing fuel than sucking fuel. I don't know what kind of pressure the P7100 needs for normal and/or higher output so I need to pick a pump with the proper flow and pressure. My 97 has a dump bed so access to the tank and lines is great. The plan is to change the pre filter and leave the stock alone. anyone have ideas or criticisms?
Old Aug 31, 2012 | 07:42 PM
tiremann9669's Avatar
I didn't know changing filter was a problem
Old Sep 1, 2012 | 01:45 AM
ricet07's Avatar
Sounds like a lot of horsing around to make filter changing easier. With what you are describing you might as well by a airdog set up and be done with it. You will have the cost in parts anyways by the time you are done trying different things getting it to work.
Old Sep 1, 2012 | 07:44 AM
mysterync's Avatar
Why not install a filter relocate kit?
Sent from my DROID BIONIC using Tapatalk 2
Old Sep 1, 2012 | 10:31 AM
ricet07's Avatar
I have one that is just sitting in the garage if you want it. Its a prime lok, took it off my 97 when I put the airdog on. I hated the dang thing, it was just something extra to unbolt and try to swing out of the way to do pump work.
Old Nov 14, 2012 | 08:34 AM
jps51248's Avatar
Default Primloc
ricet07, would you be interested in selling your primeloc? If so, e-mail me. jps scheernj@mtcnet.net
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
Gm3500
May 7, 2015 11:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
