Cutting out
Old Aug 31, 2012 | 05:39 AM
mossyoak54's Avatar
Default Cutting out
My 01 2500 starts cutting out ( like a miss fire if that's what you call it) above 2k rpm. I have all my settings on my quad turned up high to see if it is the problem. No luck. After it does it the quad beeps and says defueling. When it did it this morning egt=770 boost= 10
Sent from the mans IPhone.
Old Aug 31, 2012 | 08:53 AM
biged681985's Avatar
Sounds like a lift pump problem
cummin_un_glued's Avatar
FormerVendor
yep like ed said sounds like a fuel pressure issue, going to have to check that out
Old Aug 31, 2012 | 02:37 PM
mossyoak54's Avatar
I don't have a fp gauge but I have a brand new raptor on it. It is running but I guess that means nothing without a gauge.
Old Aug 31, 2012 | 02:44 PM
Have you downloaded a different program to the quad? Them things can be finicky. And I would also put a gauge on it to see what fuel pressure is. They make an fp adapter for the adren
Old Aug 31, 2012 | 02:50 PM
mossyoak54's Avatar
It has factory tune but I did turn timing down to 7* seems to help keep egts lower. And a fp gauge is in near future
Old Aug 31, 2012 | 03:30 PM
I would try a different tune and see how it runs
Old Sep 1, 2012 | 06:20 PM
blacksally's Avatar
mine is doing the same thing but only some times i can hear pump running and i have my smarty on 3, i changed fuel filter it was black but i run alot of used tranny fluid. its got a newer lift pump.
Dits'04SuperDuty6.0
Aug 26, 2015 08:49 PM
Dzljon
Basement Enterprises
Jul 7, 2015 09:33 PM
Dertyd
24
Jun 7, 2015 02:45 PM
