Bath Oil Seal Leak
Old Aug 30, 2012 | 09:10 PM
Sandman8105's Avatar
Default Bath Oil Seal Leak
Oil/ grease all over the rear driver brakes. I'm sure the seal is leaking and I should go ahead and change the bearings. By chance, what might be my chances that the bearings are still ok and I only need to replace the seal? Fair or slim? (Obviously I should know once I pull them.) Just hoping to luck out and looking for the odds.
Old Aug 30, 2012 | 09:31 PM
tiremann9669's Avatar
Should be able to tell as soon as you jack it up, if wheel has up and down play you need bearings.
Old Sep 30, 2012 | 04:24 AM
kcwell27's Avatar
Clean and inspect. They should be ok.
Old Sep 30, 2012 | 10:12 AM
RanchhandTCR's Avatar
wheel bearing rarely fail, but like said above Clean and inspect..
Old Dec 22, 2012 | 02:32 PM
Well, did all of the work and I have a howl coming from the right rear wheel. The bearings LOOKED good but, I guess I will have to replace them any way. Wondering if some of the sound is coming from the carrier bearing in the middle of the driveshaft.
makuloco2000
Dec 20, 2015 11:19 PM
cummins Pride
Sep 28, 2015 12:11 PM
Gomerpile79
Apr 9, 2015 03:45 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
