Problem with Edge Maybe???
Old Aug 30, 2012 | 11:32 AM
53Blocked's Avatar
Default Problem with Edge Maybe???
I have a 99 24v mods are exhaust, intake and edge comp box. Check engine light is on and had codes for low voltage to turbo boost sensor, map sensor voltage low.... anyhow so I read something somewhere and unplugged the chip from the map sensor. Results in alot more smoke(which i was expecting) the check engine light went out AND my first setting on my comp box smokes/fuels harder and runs better than my 5th setting. Sooo my chip is messed up or I am idiot and proved nothing??? Any help will be appreciated.
Old Aug 30, 2012 | 11:38 AM
H.R.D's Avatar
Sounds like the module is jacked. I would take it off and contact edge and have them check it out. If it continues to do it could be a sensor problem or ECM.
Old Aug 30, 2012 | 12:12 PM
Smarty=Cummins's Avatar
My edge comp smokes way more 1-5 than on 5-5 but 5-5 has ten times the power than 1-5 does.
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
bwbrewco
Diesel Engine Conversions
Jun 24, 2015 12:40 PM
Kfohne21
Feb 16, 2015 03:46 PM
somarillw
Dec 8, 2014 09:07 PM
