KDP help
So should just buy the kit for around 100 bucks or this tab that i found that looks like alot better solution than the actual kit
Here it is http://pages.ebay.com/link/?nav=item...d=300771424982
I just made a tab like the ebay one, the gasket kit with front seal was like 42 bucks a couple years ago when I did mine. Cant see payin 100 bucks for less than 50 bucks worth of gaskets. Loctite all of the gear housing bolts well you're at it, there's a couple behind the cam gear that you have to turn the motor over to get at.
I'd build the tab... pretty simple deal to do.. it doesn't take but a couple minutes to do and your really don't need any fancy equiptment to do it... then locktight all bolts while the gear box is open like the other fella mentioned...
51Hudson
10
Aug 5, 2015 12:32 AM
quiksilver1j
Jul 30, 2015 12:41 PM
