View Poll Results: best way to fix o/d kicking in and out
bypass tps
71.43%
clean vss sensors on trans
0%
install potention meter
28.57%
rebuild transmission
0%
Voters: 7. You may not vote on this poll
Old Aug 29, 2012 | 03:25 AM
CowboyRoy's Avatar
Default o/d kicking in and out
Howdy y'all having some problems my 93 dodge ext cab 12 valve Cummins dually . much needed help truck has only 164000 miles on it all still original. just started kicking in and out of overdrive , not for sure if its the tps sensor or one of the vss sensors on transmission . My ?is can u bypass the tps sensor? and what is a potentionmeter and how will it help and where can i get one . thanks y'all ahead of time for any and all ur help and knowledge u can give me.
thanks CowboyRoy
Old Aug 29, 2012 | 08:22 AM
92betsy's Avatar
When mine started doing this I just did the POT conversion.
Super Cool and CHEAP TPS fix! Dial-in your OD shift point! - Dodge Diesel - Diesel Truck Resource Forums
Installing a Potentiometer in place of the TPS - Dodge Diesel - Diesel Truck Resource Forums
Here is a way to get a cheaper tps to work.
http://www.dieseltruckresource.com/d...d.php?t=202697
Old Aug 29, 2012 | 10:13 AM
eljefedavies's Avatar
Default TPS
It sounds like your TPS is going out. I have a brand new for sale ($100.00) due to switching over to the POTS. My problem was the little plastic piece that is in between the TPS and the pump was worn and would cause the TPS to go out of adjustment. The POTS works great but if you don't want to do it and just replace the TPS contact me. jeffdavies500@gmail.com
Old Aug 29, 2012 | 09:41 PM
CowboyRoy's Avatar
Default many thanks
Thank y'all very much for help with my truck. cause when i was heading into work this morning it totally feel on its face 55 was the top speed with no overdrive so i shut her down and limped her back towards the house .started calling around for new tps and no such luck two day special order and over 300 dollars and i was making all these calls at dark thirty then it dawned on me to check my email. Y'all don't know how much of a life saver y'all were .I went into radio shack and got everything plus an extra one to keep in truck for spare for under thirty bucks. Well if y'all happen to wonder down around my neck of the woods give a hollar and ill grill some steaks and ice some beer down. thanks again
Old Sep 2, 2012 | 06:50 PM
thepinkzepp's Avatar
Home depot switch for the win!
Old Sep 2, 2012 | 07:48 PM
miller215's Avatar
adjust the black tab on tps sensor just did it to my shifts better than when i bought it but im even thinking about putting a pot on it
Old Sep 2, 2012 | 08:32 PM
daveO's Avatar
I used this kit and it works great!
1st/2nd Generation Dodge TPS Delete Kit *91.5-98 12v* [DNR] - $39.99 : Zen Cart!, The Art of E-commerce
Old Oct 2, 2012 | 05:49 AM
miller215's Avatar
i finally put a pot it the truck and i fixed the truck
Old Oct 2, 2012 | 07:39 AM
daveO's Avatar
Old Oct 2, 2012 | 07:52 PM
CowboyRoy's Avatar
I can guarantee the pot works
