Brought my new 980 pound toy home today.
Old Aug 29, 2012 | 02:10 AM
1stgenblowingsmoke's Avatar
Default Brought my new 980 pound toy home today.
95 2wd auto p-pump with a 180 horse pump on it, new hg and looks like head too. It's going in my 93 5 speed 4wd in a few days.
Old Aug 29, 2012 | 12:15 PM
flyingcrodeo's Avatar
Sweeeeeeeeeeeeeeeeeeeeeeet
Old Aug 29, 2012 | 04:07 PM
Ltk's Avatar
Ltk
Awesome!! Takes bunches of pictures
Old Aug 29, 2012 | 04:59 PM
I looked all over the net for a writeup on doing a p-pump swap n only found bits n pieces so more then likely I will do a detailed writeup on it. I've already had my fingers in the pump, slif the plate all the way forwards n same with the afc housing. Gonna run my 24v hx35 with a 16cm non gated housing that I have for now .
Old Aug 29, 2012 | 05:17 PM
Red_Rattler's Avatar
High Tech Redneck
P-Pump FTW
Old Aug 30, 2012 | 02:16 AM
Originally Posted by Red_Rattler
P-Pump FTW
I know I know I'ma trader n used to bug people for doing p-pump swaps into 1st gens. But when I can buy a running p-pump with 303k km on it or a 93 ve with 350k km on it for 300 bucks more I'll take the p-pump.
Old Aug 30, 2012 | 07:25 AM
Gas's Avatar
Gas
What happened to the ve engine?
Old Aug 30, 2012 | 12:34 PM
Cracked block. Didn't realize it when I got it as she never leaked in the middle of winter until outside temps started coming up she started leaking more n more.
Old Sep 4, 2012 | 02:04 AM
Well guys I started it today, The VE took her last breathe at 10-30 this morning. So I pulled everything off the drivers side electrical related, fuel related including my 2nd gen lp n regulator, throttle cable which I will slightly mod to fit the p-pump, boost gauge line, intake tubes on both sides,vac power steering pump have been removed from the motor but still in the truck to avoid re bleeding the power steering system, battery is out, Turbo is out along with the exhaust mani which I gave to dad since his on his 96 is shrunk, all the front stuff is switched over, alt, fan bracket n fan, belt tensioner( 95 one was broken).
The water temp probe I still gotta remove, fuel return line, then unbolt the bell housing and motor mounts n lift her out.
So here's the pics from today.
Before I tore into it.
Wiring, intercooler tubes,fuel lines n throttle cable offoff.
Rad n fan gone.
Starting to take off the turbo.
Turbo and exhaust manifold off. You can see my previous attempt to save the block or atleast prolong it's life since it only has 201k km on it.
She's almost ready to come out.
Was gonna pull the front clip, drop the t-case n pull the tranny but dad n I decided to leave them both in n slide her forward n straight up.
What's going in tomorrow.
One nice thing about how the thermal switch and KSB is wired up is that you will never tell by looking at the wiring that it was there, there's no stray plug, no cut wires no nothing as it gets power off the fss then goes to the sensor then to the KSB. So since those are both related to the VE and don't plug into the factory harness it will never be known that it was there.
Old Sep 7, 2012 | 06:51 PM
Gas's Avatar
Gas
Got any closeup shots of the crack?
