Loosing fuel prime when parked on driveway
Old Aug 27, 2012 | 07:57 AM
Whiteyelwood's Avatar
Default Loosing fuel prime when parked on driveway
Howdy again men! I am having an issue with not being able to start my truck untill I let my FAS pump run and build pressure for about 15 or 20 seconds when the truck has been parked on my driveway for a few days(my driveway has a pretty good incline). It never did it on flat ground untill a few days ago but I think it had been sitting for longer than that that time. I was thinking there may have been a bad check valve somewhere in the fuel system and the angle of the truck was letting the fuel drain back to the tank or something.But that would mean air is getting in and I doubt that. Does anybody have ideas.
Thanks
Whitey
Old Aug 27, 2012 | 09:50 AM
RAW's Avatar
RAW
99% of the time this is caused from the banjo bolt on the back of the head being loose, and allowing air into the system. Mine did the same until I tightened it up.
Old Aug 27, 2012 | 09:23 PM
tiremann9669's Avatar
Could also be a leak in the fuel line somewhere sometimes they let air in without leaking fuel out,
Old Aug 28, 2012 | 08:09 PM
CumminsNewbie88's Avatar
I had the same problem and mine ended up being a fuel leak/air getting in the line! fixed the leak and starts like a dream now!
Old Aug 28, 2012 | 09:53 PM
01quadcab's Avatar
back truck into driveway so front end facing downhill if this cures it your crossover tube o rings need done
Old Sep 6, 2012 | 06:08 PM
russellflemister's Avatar
i had the same problem i had to change the fuel return banjo bolt on the injection pump the little ball in it can stick open and the fuel will drain out of the injection pump down the return line to the tank
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
