fuel cutoff relay questions
Old Aug 26, 2012 | 12:12 AM
redneckairman's Avatar
Default fuel cutoff relay questions
ok so a few questions.
1. what is the pourpes of the fuel cutoff relay
2. where is it located at in an 01 ram
3. do i need it with an after market fuel pump system
4. can i just put a jumper to isolate it if its not needed
if anyone can help with theis questions it would help me and maybe just get my truck back to were it needs to be
Old Aug 26, 2012 | 08:07 AM
mysterync's Avatar
What's the problem that leads to your question? Sounds like you've got a code that's lead you to this.
Sent from my DROID BIONIC using Tapatalk 2
Old Aug 26, 2012 | 12:35 PM
Well someone had mentioned it and when it dose shut off only the motor shuts down nothing else
Old Aug 26, 2012 | 12:41 PM
mysterync's Avatar
There's a asd relay? Have you had the truck to a shop to diagnosis this or do you have the tools and capability? Have you checked fuel pressure at the time of stall? Have you ran the injection pump in stand alone to verify if there's still a issue with the truck stalling? Have you verified 12v + and ground at the injection pump? You have to know what's causing the stall to fix it, you could throw lots of parts at it and never repair it correctly.
Old Aug 26, 2012 | 09:54 PM
well i got it runnig and driving around today but im still wondering if i fixed the problem. i have heard some people say if the tank is under a 1/4 the truck will start acting up. so could that be what it is because at the time it stopped it was under a 1/4 tank but then what would cause that problem
Old Aug 26, 2012 | 10:05 PM
mysterync's Avatar
Do you have a traditional draw straw in your tank.
Old Aug 27, 2012 | 06:40 PM
im not sure as far as i know it is nothing has been messed with in the tank
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
