Is it turbo lag?
Old Aug 24, 2012 | 09:48 PM
drose's Avatar
Default Is it turbo lag?
I am new to diesels and turbos. I have an 02 cummins HO I find that when I'm in 5th and 6th gear if rpms stay steady around 1400 or so when I get into the throttle no response at all. Shouldn't there be enough power to spool up the turbo? I do have the p0216 code could lack of fuel be causing this? The truck never smokes no matter how much throttle I give it.
Old Aug 25, 2012 | 06:33 AM
Rooster24v's Avatar
is the truck stock? stock turbo? you shouldnt have much lag with the stock turbo, what if you get the rpms up a little does it spool then?
Old Aug 25, 2012 | 10:28 AM
biged681985's Avatar
The p0216 is the vp death code. So it's most likely your pump isn't responding like it needs to
Old Aug 25, 2012 | 02:03 PM
drose's Avatar
A new vp44 and air dog are going in next week. everything on the truck is stock except for a straight pipe exhaust that was on it when I bought it. It will spool back up if I get the rpms up but it won't do that without downshifting or taking it out of gear and putting it back.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
GreenDieselF
Oct 20, 2014 02:05 PM
