tranny heat problems
Old Aug 22, 2012 | 08:13 PM
dango's Avatar
Default tranny heat problems
I have a 99 cummins with a rebuilt tranny in it with only about 7000 miles on it. It also as a brand new radiator but my tranny tends to get really hot on occasions. my temperature records on my chip show that its hit 286. Any suggestions?
Old Aug 23, 2012 | 07:10 AM
RAW's Avatar
RAW
Wow, that's way too hot. Have you confirmed that is the actual temperature?
Old Aug 23, 2012 | 08:34 AM
Ed ke6bnl's Avatar
when does it read these temps. are you towing or just by itself.
Old Aug 23, 2012 | 08:59 AM
dango's Avatar
i have an edge juice with attitude and ive seen it read 230ish just driving not towing. the 286 came from the chips records section
Old Aug 24, 2012 | 02:41 PM
1AMatt's Avatar
Site Sponsor - 1aauto
I dont think i've ever seen a Trans that hot before
Old Aug 29, 2012 | 02:48 PM
hugho's Avatar
you wont have a tranny for long with temps that high. it's not cooling. there is a phenolic check valve I think in the cooling lines which might be sticking. some shops recommend removing it. I would take it to a high end shop and have it power flushed and put in new ATF while youre at it! I would check if you have a warranty as well because you may need it real soon!
Old Aug 29, 2012 | 03:13 PM
RAW's Avatar
RAW
This may not be something it actually read for real. During install a wire may have shorted to ground, or something similar, to get that record. A coworker bought a '02 with an EJWA. His highest recorded RPM is 5,850.......I highly doubt that engine turned that fast. You could reset your records, and see what happens after that.
Old Aug 29, 2012 | 05:29 PM
dango's Avatar
alright thanks for the help man. i'll try that and go from there
AHAAN
Jul 19, 2015 10:28 PM
peterbilt
Chevy/GMC Duramax 06-07 LBZ
Apr 8, 2015 10:33 AM
Ol Goat
Jan 22, 2015 02:16 AM
corey352
94-98 7.3L Performance
Oct 22, 2014 10:58 AM
gorman1214
Oct 20, 2014 10:48 PM
