transmission swap ? for Overdrive
Old Aug 21, 2012 | 08:36 PM
k0mik's Avatar
Default transmission swap ? for Overdrive
I got a 1985 ford - f250 w/ 6.9 diesel with 1, 2 , and under drive i was wondering if a transmission with overdrive can be put in and if so will a4od be a better option if at all verses e4od which i have one out of a 91 f250 although that was just a 5.0 motor {probably wont work} ?
Old Aug 21, 2012 | 10:25 PM
Kickin IdI's Avatar
If your tranny is mechanically sound, and Ur just lookin for od, U could look for a divorced overdrive unit to install in between the transfer case and the rear axel. It's easyer, and depending where you get one and the parts, it could also be cheaper. I had one on my 2wd Chevy 383 hot rod c10. It had a t400 and 4:10s, and once I was on the hwy I just flipped a switch and bam... Went from 4000 rpm at 85 to 2900, and gas mileage went from 8 to 9 . Seriously tho, you can find one for cheep, and even use it as a gear split if your hauling heavy and shift manually.
autostroker
Jun 17, 2015 11:18 AM
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
