stock manifold!
Old Aug 21, 2012 | 06:15 PM
scottmorgan's Avatar
Default stock manifold!
i have a stock 6.7 manifold and i am putting it on my 5.9 to use the vgt turbo! what is the little port half way down the manifold used for on a 6.7? it looks to be a 1/4" npt fitting port with a hole all the way through. i was going to use it for a egt probe bu i went to put a 1/4" npt to 1/8" addapter in it and it would not thread in. i will force it if some one can reasure me that it is indeed a 1/4" port not a metric or anything. pic of what i am talking about below! it is the red circle not the greeen line
Old Aug 21, 2012 | 08:10 PM
Red_Rattler's Avatar
High Tech Redneck
Not sure of the size but im guessing its where the factory ecm get its drive pressure readings from
Old Aug 22, 2012 | 08:56 PM
DodgeIt870's Avatar
it is 1/4 inch, but it is flared fitting that went there. i took all that stuff off my 6.7.
that port went to the thermostat housing. and it is a fine thread not standard iron pipe size.
Old Aug 23, 2012 | 08:03 AM
JackedUp's Avatar
Need to drill and tap it.
Old Aug 24, 2012 | 05:02 PM
drill and tap it sounds like a plan and i love the simi on fire!!
is a fine thread 1/4"-1/8"npt even avalible?
Old Oct 2, 2012 | 03:37 PM
FreeseDiesel's Avatar
it is a bung for exhaust pressure readings for dpf system.
06dodgecummins
Jul 13, 2015 11:24 PM
Notdaddysmoney
Jul 10, 2015 12:25 PM
wannadrag
May 25, 2015 03:07 PM
Old12er
Feb 20, 2015 10:35 PM
cummins Pride
Oct 23, 2014 01:10 PM
