Injector and turbo help
Old Aug 21, 2012 | 03:43 AM
jfollowell's Avatar
Default Injector and turbo help
Hey guys lookin to buy a set of injectors proly gonna go with ddp 100's/150's can't really make up my mind. I'm also thinking of the ats aurora4000. Would this be a good setup or which turbo would yall recomend. Only looking to get about 400-500hp out of her.Truck is 02 5spd, edge comp,4" tbe, Fass titanium 150. Thanks
Old Aug 22, 2012 | 04:55 AM
globalwarmingcontributor's Avatar
if your only looking for about 4-500hp on your rig, id look into an industrial injection 62mm turbo with a set of 100hp injectors. that would be a good stack with your edge comp and Fass pump. i wouldnt go with anything bigger than a 62mm though, reason being is because anything bigger may be laggy off the line, and may be rough if towing
Old Aug 22, 2012 | 07:12 AM
Ya a 62mn Turbo and 100s should get you in the low 400hp range.
Luke
