need help on install my fp gauge
Old Aug 20, 2012 | 11:01 PM
blacksally's Avatar
Default need help on install my fp gauge
i got a fuel pressure gauge and need to install it on my 99 dodge where is a good place i dont have a banjo bolt i seen on you tube videos, i have two brass plugs on top of my filter housing can i use one of those are no thanks any help would be awesome!!!
Old Aug 21, 2012 | 01:00 AM
pukie370's Avatar
the best place is fitting going in to injection pump.
Old Aug 21, 2012 | 08:08 AM
blacksally's Avatar
like wheres that located tthe main line going into the pump so id need to buy the fittings etc?
Old Aug 21, 2012 | 05:11 PM
JBearSVT's Avatar
Follow the line out of your filter, it will lead you to the injector pump. You will probably need to buy a tapped banjo bolt like the one from Tork Tek.
Old Aug 21, 2012 | 05:14 PM
blacksally's Avatar
i seen it today when i replaced my strater imma order the banjo bolt and regulater for it i hooked it all up but the sensor it reads 30 psi that because its not hooked up im guessing?
Old Aug 21, 2012 | 05:16 PM
JBearSVT's Avatar
If it's not hooked up it shouldn't be reading anything? I guess I don't understand what you did.
Old Aug 22, 2012 | 10:56 AM
vineyardm's Avatar
Your best bet is to go to Vulcan - and get their "Big Line" kit that replaces existing hardware (smaller diameter line and banjo bolts) with bigger line, AN fittings, etc. The 90 deg. elbow that connects to the VP44 has, on the "back side" a port for 1/8" NPT fitting. Unscrew the plug ...put a new flexible grease gun line (about 12") ...then add a snubber at the end, and put your fuel pressure sensor at the end of the grease gun line (...mount on the fender wall) ...and now you are "good to go". This gives you better flow, eliminates the horrible banjo bolts that restrict fuel flow, mounts the sensor away from engine vibrations, etc. What's not to like???
Old Aug 22, 2012 | 08:22 PM
blacksally's Avatar
sounds good thanks
huntman7
Sep 4, 2015 04:49 AM
MrCat4974
Mar 23, 2015 11:30 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
450r racer
Nov 14, 2014 05:11 PM
scottxmorris
Oct 8, 2014 02:14 PM
