Cranks but no start- help please
Old Aug 20, 2012 | 09:55 AM
Sam Wiborg's Avatar
Default Cranks but no start- help please
2005 F-250 cc with 6.0 auto 4x4 170,000mi. Edge juice with attitude. Been running Great. Last week it took a few seconds to start and would run kinda sluggish and smoke a little white and black til it got warmed up. Yesterday I turned it off to get fuel and it would crank and crank but no start. It canks strong. I tried it last night and I couldn't read it quick enough but it said some kind of fault? Any ideas? I don't drive it much other than to go into town every other week but I don't wan it just sitting around. I've driven it maybe 100 miles in the last 3 weeks. Thanks guys
Old Aug 20, 2012 | 10:27 AM
Mdub707's Avatar
Does it restart fine once it's cooled off? Does it only seem to happen when the truck is warm? Probably the STC fitting on the HPOP.
Old Aug 20, 2012 | 03:20 PM
Sam Wiborg's Avatar
No. It wont start at all. Just cranks. After about 5 secs it says tpc fault on the dash. I check the Ipc sensor and I didn't see any oil in it. I live 40 mi from town and don't have a way to check codes. Is there anyway to test the hpop or the stc or the crank position sensor or the iPr?
Old Aug 20, 2012 | 03:31 PM
Mdub707's Avatar
TBC fault is just the brake controller, I wouldn't worry about that right now.
When you crank, look to see if the oil pressure gauge on the dash comes up. You may have to crank for a while, mine took like 6-7 full seconds before it comes up.
Old Aug 20, 2012 | 04:51 PM
bobfbigman's Avatar
One thing to note is if you have an oil bypass system it may even take longer for it to show pressure on the guage, check the bassics, fuel, oil pressure , air. you can pull the IPR to see if the screen is torn and holding the ipr open.
Old Nov 11, 2012 | 11:35 PM
cavscout's Avatar
i have a 04 f250 sound like i am having the same problem i bought my truck last a week ago and it ran great i put an edge tuner on it and it started right up ran bad *** went to turn the truck off for like 10 min and when i tried to start it would not start just cranked and cranked about 4 hours later went back and cranked it about 10 times and it started drove it home parked it pluged it in and came out the next morning had to crank and crank it to get it to start when it did i drove to my shop noticed at idle had no oil pressure but when i gave it gas oil pressure was fine not it will not start and just cranks any ideas of what could be wrong i need my truck back yesterday thanks
can you look at my post on this same thread
Old Nov 12, 2012 | 08:23 AM
Mdub707's Avatar
Sounds like the low pressure oil pump may be going out...
OR, wrong oil filter, like one that uses it's own cap... seen that quite a few times too. Check the oil level as well. Low oil means no oil going to the high pressure oil pump, which means injectors stop firing.
Old Nov 12, 2012 | 08:37 AM
cavscout's Avatar
The oil filter area is filling up so what should I look at next hoop problem
Old Nov 12, 2012 | 08:46 AM
Mdub707's Avatar
How do you know it's filling up? If your oil pressure gauge on the dash is dropping, that means you're not building low pressure oil. Low pressure feeds the high pressure, so if you're losing low pressure, you're certainly not going to have high pressure. We need to start at the beginning and work our way back to the hpop.
Old Nov 12, 2012 | 08:49 AM
cavscout's Avatar
I took the oil filter out pushed the ball down and cranked it and the filter arra filled with oil
