need help. running rough cold
Old Aug 20, 2012 | 12:21 AM
burnhedge's Avatar
Default need help. running rough cold
I recently bought a 95 cummins. The first start every day it would run really rough,puff white smoke,and sometimes die when put in gear. Once it warmed up it was fine. I realized it was only idleing at 400rpm so i took it up to 800 and it ran perfect for 2 weeks. Now its back to the same thing even idleing at 800. I drained the water seperator and its still progressively getting worse. Could the lift pump slowly be going bad? Any ideas? thank you
Old Aug 20, 2012 | 12:55 AM
cummin_un_glued's Avatar
FormerVendor
yes the lift pump could be bad, start with a fuel pressure test then i would also do a compression test.
Old Aug 27, 2012 | 02:55 PM
burnhedge's Avatar
Ok so i changed out the lift pump and took out the fuel heater. Neither were the problem. Can someone walk me through how you test for leaks by pressurizing the tank. Thanks
ssmith.77
Nov 25, 2018 06:56 AM
Dieselhead6.5
Oct 6, 2015 09:47 AM
ssmith.77
Jan 11, 2015 02:03 PM
f250white
Jan 11, 2015 09:25 AM
iMixDiesel&Gas
Dec 27, 2014 09:57 PM
