Leaking Oil!! :(
Old Aug 19, 2012 | 07:11 PM
SRTcummins's Avatar
Default Leaking Oil!! :(
Im leaking oil under my power steering pump. it could be engine oil or trans oil but i cant tell the difference because of the change of color when it hits my dirty frame and other parts. I live on a dirt road so i have many problems seeing things when it happens. my trans cooler lines are right near the spot to so i was thinking it could be them also. I havent seen any where else it could be leaking from. if anybody has had this problem please let me know!
Old Aug 19, 2012 | 09:45 PM
blacksally's Avatar
vaccuum pump? front cover power steering box alot of stuff man id check to make sure what color it is and go from there
Old Aug 19, 2012 | 09:51 PM
GuyWithA24Valve's Avatar
I bet it's the vacuum pump. Mine leaks bad.
Old Aug 19, 2012 | 10:53 PM
RanchhandTCR's Avatar
smell the oil tranny fluid has a completly different smell compared to diesel engine oil. It kinda smell like diesel exhaust if its oil. But vaccum pump or a bad seal on your steering pump
Old Aug 19, 2012 | 11:51 PM
blacksally's Avatar
yea my front cover leaks a tiny bit no worries till shes comin like a water fall hahahaha
Old Aug 20, 2012 | 04:09 PM
RollinCoal99's Avatar
crank case or just your blow by
Old Aug 20, 2012 | 09:43 PM
lunk's Avatar
vaccum pump
Old Aug 21, 2012 | 08:54 AM
SRTcummins's Avatar
I took it to the shop and they said it was the vacuum pump. its too high to be the blow by off of the IP. he said 275$ and its fixed. He said i have to buy a kit and blah blah. but he said it would take him 2 hours..Would i be able to do this myself? I have mechanical know how and all the tools in the world. Im just wondering if it would be too hard of a thing to do.
Old Aug 21, 2012 | 05:01 PM
BarryB's Avatar
While your at it double check your lifter cover on the side of the block. Mine started pouring oil. Was told it was the vacuum pump. turned out it was that lifter cover gasket had cracked. it has like 3-4 bolts holinf to the block and is located right behind the IP.
If your good with wrenches, theres a video on just about every common fix for a cummins on youtube. Thats what I usually do, watch several then tackle the project. save myself alot of money.
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
jhprice
Mar 29, 2015 09:36 PM
coors_man_2005
Dec 15, 2014 10:23 AM
