STALLS IN REVERSE
Old Aug 19, 2012 | 02:39 PM
Strok-n's Avatar
Default STALLS IN REVERSE
Hey guys on my 1996 Dodge I am having a problem in reverse. Whenever I put it into reverse the truck starts dropping rpms, and if I dont let off of the brake it will die. The idle is set at 850RPM and I adjusted the TPS today to sit at 1.3 volts at idle. Just wondering if anyone has any input on this.
Old Aug 23, 2012 | 04:09 AM
Mike337's Avatar
Is the idle set with the dash tach or with a plug in to the computer?
There is a TSB telling you not to use the dash tach. Ram Diesel Problems
Also did you set it with the A/C on?
1994-1998 with AT - in drive with AC on 750-800 RPM
1994-1998 with manual in neutral with AC on 750-800 RPM
NOTE: These speeds may cause stalling when the engine is cold. If this is a problem for you, bump the idle speed to 900 RPM.
Also See: https://www.dieselbombers.com/94-98-...djustment.html
Old Sep 4, 2012 | 01:31 PM
Strok-n's Avatar
hey re adjusted the idle this weekend to 800rpms using a scan tool, and I am still having the issue.
Old Sep 4, 2012 | 09:30 PM
xzaq103's Avatar
FormerVendor
Could be any number of things. From the pump to injectors to a tight converter. Might try and bump it up to 900rpm.
Who built the pump and what GSK kit?
Chris
alexcummins2341
Jul 31, 2015 11:21 PM
redjello
Apr 13, 2015 08:27 PM
99&91cummins
Feb 28, 2015 09:28 AM
97PS
14
Feb 19, 2015 11:21 AM
irishbmx
Nov 19, 2014 01:47 PM
