Weird ABS light and power window problem
Old Aug 19, 2012 | 12:58 PM
jhughes76's Avatar
Default Weird ABS light and power window problem
I have a weird problem. I have a 1990 IDI, and every time I shift from drive to reverse when I am parking the truck, the ABS light comes on and the power windows will not roll up. I can turn the truck off, and then switch back on, and the lights are fine and the ABS light is off. I have seen things on the forums about just the light, but haven't seen anyone else have this weird combo. The issue is not really causing any problems right now, but I am afraid it may get worse and leave me stranded somewhere. Has anyone else experienced this?
Old Aug 19, 2012 | 09:01 PM
dukes-78's Avatar
Electrical gremlins can be a hard thing to track and they can leave you angry and banging your head against a wall. It seems that every time you have this problem is when you shift from drive to reverse, so I would start by checking down in the column for a broken or chaffed wires in the ignition harness, which is not an uncommon issue.
burndiesel
10
Feb 7, 2023 01:15 AM
Radioking1777
Jun 9, 2015 04:13 AM
