Coolant problem??
Old Aug 19, 2012 | 11:12 AM
Ty769's Avatar
Default Coolant problem??
I have a 2006 f350 6.0l and it is leaking coolant out of the resivor cap. I pressure tested it up to 20psi for 15 minutes and it dident drop any pressure so im not sure where to start. New cap maybe??
Old Aug 20, 2012 | 09:47 AM
Mdub707's Avatar
Well if the system holds 20psi, it means that your engine is adding MORE pressure than that and causing it to blow out. If the cap was bad, it wouldn't hold 20psi for any amount of time. Probably blown headgaskets if I had to guess.
Old Aug 20, 2012 | 01:52 PM
Ty769's Avatar
I tested the pressure today its it pushing out over 16psi. I have egr delete and apr head studs also
Old Aug 20, 2012 | 03:26 PM
Mdub707's Avatar
Doesn't mean the gaskets are not blown, BUT, try getting a new cap first, they're not very expensive. Napa has them for like $5....
Where is your coolant level? The MIN line is the MAX you should have in when cold.
Old Aug 20, 2012 | 03:36 PM
Ty769's Avatar
Its not the cap i tried that. I fill it to the min level but after a day of driving its way down
Old Aug 20, 2012 | 04:13 PM
cummin_un_glued's Avatar
FormerVendor
Which gaskets were used when the studs were put in
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old Aug 20, 2012 | 04:42 PM
Ty769's Avatar
Im not sure i dident put them in
Old Aug 20, 2012 | 11:31 PM
FormerVendor
I have heard of problems with the black gaskets even with studs.
Old Aug 21, 2012 | 07:59 AM
Mdub707's Avatar
I blew OEM ford gaskets with studs too, because Ford doesn't know how to measure flatness on a head or properly torque ARP studs apparently.
If the cap is changed, you don't have an EGR cooler and you're pushing coolant still... your headgaskets are blown. I guess it's possible the heads just have cracks too, but in this case blown gaskets are the better option.
Who did the work?
Old Aug 23, 2012 | 07:47 PM
Ty769's Avatar
So i took the truck to the shop today and sure enough its the head gasket
