2004.25+ 6.0 Diesel No Start/No Pressure ICP
Old Aug 18, 2012 | 10:31 PM
saranay's Avatar
Question 2004.25+ 6.0 Diesel No Start/No Pressure ICP
Continue on from the previous topic https://www.dieselbombers.com/ford-p...-cylinder.html
I've replaced a new seal on the injectors of passenger side. After of all those trouble. I still can't get my truck to start. I have tried to crank for a minute straight with 2 trucks jumped on both battery. It won't start
I scanned with OBDII >>>
There is no oil pressure reading from ICP. But I do get oil pressure read on the gauge at normal pressure. The feed back from IPR sensor is normal. I pull out the ICP sensor and crank up. I see oil coming out from ICP plug. Also go for the samething at filter housing, oil is flowing out.
I have not replace a new standing pipe and dummy plug yet. Because I have checked the seals on them, no tears or cracks on them. Could that be problem? I need to replace a new dummy plug and standing pipe? Or could that be bad HPOP, STC or IPR?
Old Aug 19, 2012 | 01:12 AM
bobfbigman's Avatar
Did you get a code for which injector it was, I thought you said it was #8 in the other thread but 8 is the back cylinder on drivers side.
the standpipes are supposed to be replaced when you remove the oil rails, ford does not consider them reusable once they have been seperated.
Tousley Ford has a kit with the standpipes and dummy plugs together, part number is
6E7Z-9A332-B and it used to be about $102
Old Aug 19, 2012 | 07:01 PM
saranay's Avatar
Oh no.. correction* is injector #7. The standpipes and dummy plugs are still in a good condition to me and I torque it 60 ft-lbs. But as you have mentioned, I will replace them.
Update* I have found the leakage after I applied air pressure test down to the ICP. And is the new injector that I bought!?! It missing oil ring and high oil pressure seals at the top that connected to the oil rail.
I tried to call the website that I bought injector from. But I think they close on sunday. Their voice mail box is full to leave a message. I just sent an email to notify them about this. Hopefully they will send me that missing parts.
Anyway I went to Lowe and buy a rubber seal from pluming section and put them on the injector. The truck is now run, but can't drive no where because the oil still flowing out from that new injector.
Old Aug 19, 2012 | 07:44 PM
bobfbigman's Avatar
OH CRAP!!!!, that will definately do it....
I recommended someone els to check that just last night, check out, the thread/ Hot no start whats the best test to run?
Last edited by bobfbigman; Aug 19, 2012 at 07:44 PM. Reason: Automerged Doublepost
Old Aug 19, 2012 | 08:54 PM
saranay's Avatar
I actually did read through that post this morning. You have provide a useful resources and tips.
I have the injector repair seal kit, but I don't have that oil ring that connects between rubber seal and retaining clip.
Hopefully they will respond and mail me that part by this week. Also this week if I have all the parts here. I will post up pictures.
Thank you again bobfbigman
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
ish1521
Aug 26, 2015 08:42 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
irozchris
Mar 14, 2015 11:16 PM
bbstimey
10
Oct 9, 2014 08:34 AM
