cummins wont shift into overdrive
Old Aug 18, 2012 | 05:34 PM
parsons_vr6151's Avatar
Default cummins wont shift into overdrive
i bought the truck with a bad transmission. last week i had the transmission rebuilt and the overdrive does not work at all. the tc locks up perfectly but will not shift into overdrive. i had to install a tc lock up switch to make the tc lock but still will not shift into overdrive.... i have replaced the tps sensor and the crank position sensor and still have no progress. somebody help im stumped!
Old Aug 19, 2012 | 10:19 AM
osjr843's Avatar
Have you checked the speed sensor
Old Aug 19, 2012 | 10:22 AM
Default Overdrive
If it was the speed sensor that was bad wouldn't my speedometer not work?
Old Aug 19, 2012 | 12:33 PM
lodal cummins's Avatar
Are you sure you gapped the crank position sensor correct?
Old Aug 19, 2012 | 05:38 PM
Default Overdrive
Ya it was gapped correctly.
i found an air bag sensor module under the seat that is not plugged into the truck... its black and has 3 bolt holes in it. would this cause the truck to not shift into overdrive by chance
Last edited by parsons_vr6151; Aug 19, 2012 at 05:38 PM. Reason: Automerged Doublepost
Old Aug 22, 2012 | 08:52 PM
alliancediesel's Avatar
Sounds like you are on it. Maybe a bad solenoid or leaky seals in 4 th gear. I now u didnt want to hear that. Autos are tricky just because it was rebuilt doesnt mean it was done correctly.
Old Aug 22, 2012 | 11:13 PM
Default Overdrive
Ya it was built correctly. Just bad wire somewhere. The truck shifts perfect now on a tc flip switch and an Od switch
Old Aug 24, 2012 | 11:09 AM
1AMatt's Avatar
Site Sponsor - 1aauto
The TC lock up switches work great! If your tranny isnt beefed up your gonna kill it though
Old May 26, 2016 | 10:54 AM
Guyco01's Avatar
Parsons im having the same problem with my tranny could you explain the od and tc toggle swotches so i can try that
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
rabidrabbit
Mar 6, 2015 03:47 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
