24 valve thermostat?
Old Aug 17, 2012 | 03:06 PM
joecool911's Avatar
Default 24 valve thermostat?
My truck runs consistently 190*. Is there a reason that it would not be wise to install a lower temperature thermostat. Seems like everything would run cooler, no just the motor. Less radiant heat on the vp44, intercool, etc.
Old Aug 17, 2012 | 03:55 PM
H.R.D's Avatar
You can certainly run a lower Tstat. The lowest one I have personally seen is around 180*. Do I think you will see much benefit from around 10*, no, but if you want to by all means have at it my friend. c:
RA113024
Mar 13, 2016 07:42 PM
Dustin M
May 21, 2015 10:19 PM
Brody Olson
Mar 28, 2015 05:14 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
