more charging problems..
Old Aug 16, 2012 | 06:29 PM
jdbigblue12v's Avatar
Default more charging problems..
new alternator and battery and truck still only charges at 10 volts but has 14.6 coming out of the alternator and battery is showing 14.6 volts also but in the cab voltmeter in the dash shows just over 8 volts and the lights will flicker on and off when on but battery still reads 14.6 volts? in serious confusion right now and dont know what to do? possible bad voltage regulator? its a 1993 w250 so its internal to the PCM correct?
Old Aug 16, 2012 | 08:54 PM
Carrnutt's Avatar
What is the voltage with the truck not running vs running? That will tell you if the alternator is putting out properly (although 14.6v sounds correct). There may be a problem in the wiring or a connection to the cab as opposed to there being an alternator problem too.
Old Aug 17, 2012 | 01:45 AM
jwirth's Avatar
PCM is the regulator for that year model if someone hasn't rigged it all up already. Sounds like you have a loose connection. Need to be %100 sure Alt is changing and that battery is getting the charge. Then check the gauge problem
Old Aug 17, 2012 | 03:19 AM
that alternator is putting out 14.6 while running and battery when truck is off is reading over 17 volts. the truck has no rigging of external voltage regulator the truck was bone stock and jjust a daily for previous owner
also when the truck is running the speedometer bounces randomly. problem started when my brother got WD-40 in the alternator and killed it but i continued to drive it while it only put out (in cluster reading) maybe 10 volts.
Last edited by jdbigblue12v; Aug 17, 2012 at 03:19 AM. Reason: Automerged Doublepost
Old Aug 17, 2012 | 03:41 AM
jwirth's Avatar
Battery is being over charged 17 volts isn't good.
Old Aug 17, 2012 | 08:40 PM
ok so got the external regulator in a few hours ago and now the dash volt-meter is showing 17 volts and it is shakey but if i rev it it seadys out at 17 volts. could this be a bad regulator out of the box?
Old Nov 15, 2012 | 08:56 AM
shanethepain's Avatar
Could you please tell me how you wired this up because it seems like no matter how i wire mine up in my 24 valve it just wont charge i cant even get mine off of 11 volts when its running then if i let it sit over night it will be dead the next day and i mean completely dead to where my batteries wont even let any of my lights come on but my batt, and alt, is good
Old Nov 15, 2012 | 09:05 AM
bladeyamaha's Avatar
Solve one problem at a time, Ohm out the wires and make sure everything is good before you replace parts. Or you are wasting your time the hard way.
Bloom12valve
Oct 9, 2015 03:40 PM
Brody Olson
Chevy/GMC Duramax 06-07 LBZ
Sep 12, 2015 11:01 PM
Zachbishop
Feb 10, 2015 10:23 AM
JRB1960
Dec 1, 2014 09:24 PM
yams
Audio Equipment/Electrical
Nov 29, 2014 09:25 PM
