Crank questions
Old Aug 16, 2012 | 05:53 PM
CumminsKid6's Avatar
Default Crank questions
I got along block for cheap and was gonna build it up slowly. And was wandering will it change anything putting a 6.7 crank in it.
Old Aug 16, 2012 | 10:21 PM
cummin_un_glued's Avatar
FormerVendor
372 cubic in with a standard bore. you would have to mill off the top of the pistons to make it work.
Old Aug 17, 2012 | 01:08 PM
1AMatt's Avatar
Site Sponsor - 1aauto
So would a newer wouldn't really give you that much more displacement then?
Old Aug 17, 2012 | 04:56 PM
FormerVendor
To get the 6.7 displacement one would have to also bore the block to 4.200 and run aries or ross pistons.
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old Aug 18, 2012 | 02:36 PM
That'd be fine by me. I mean considering I just wanna build the motor up anyways.
Old Aug 18, 2012 | 10:30 PM
FormerVendor
keep in mind that to bore out to 4.200 is a .180" bore increase on a 5.9 block
Old Aug 19, 2012 | 08:14 PM
Would it be possible to do. If so who could I get pistons and rings from to make it work
Old Aug 19, 2012 | 11:47 PM
FormerVendor
yes it is possible but i wouldnt do it in a street engine because the cylinders will start getting thin since the 5.9 passes water between the cylinder and the 6.7 block is soild between them. yes aries and ross make piston and ring sets up to atleast 4.250" that i know of. if you really want a 6.7 12v i would suggest using a 6.7 block. otherwise the slight increase in displacment from the crank only wouldnt be worth the extra cost of buying a 6.7 crank and having the pistons machined off.
Old Sep 2, 2012 | 09:37 AM
Ten four. I appreciate it. I'll have to look into that some more
Mar 20, 2015 08:20 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
weatherby
99-03 7.3L Performance
Nov 5, 2014 10:45 PM
