Dead petal only at over 65mph
Old Aug 16, 2012 | 05:30 PM
stevescummins's Avatar
Default Dead petal only at over 65mph
I am having a dead pedal problem that only happens in 5th gear at 66mph or faster. If I stay in 4th gear and run the same rpms it runs fine. I replaced the TPS and speed sensor within the last year. My fuel pressure is good. I am moving back up north in 3 days and this starts happening. Any ideas? Thanks Also it does it with the adrenaline turned on or off. No difference. I checked for codes by cycling the ignition and it comes up clear.
Old Aug 16, 2012 | 06:12 PM
RAW's Avatar
RAW
By dead pedal do you mean the RPM's drop off, or what exactly. Do you run out of power?
Old Aug 16, 2012 | 06:18 PM
It is like the fuel gets shut off instantly and the boost falls flat then if just takes off again. I just came back from the parts store and they got no codes with the scanner. As long as I stay under 65mph it runs fine.
Old Aug 16, 2012 | 06:32 PM
RAW's Avatar
RAW
Sounds like its being governed. You used to be able to go over 65? Can you do 65 or 66 in 4th?
Old Aug 16, 2012 | 06:51 PM
Yes I can. It doesn't do it all the time but the more I drive it the worse it gets. I just drove 200 miles and as long as I stayed under 65 I was ok. Sometimes I would get going 75 and it would be ok for a little ways and then start cutting out again until I got under 65. Weird.
scottxmorris
Jan 11, 2025 11:24 PM
burndiesel
10
Feb 7, 2023 01:15 AM
Daylon
Aug 22, 2015 02:04 PM
12vlejeune
Nov 19, 2014 05:39 PM
