transmission trouble
Old Aug 16, 2012 | 09:29 AM
Fuelburner's Avatar
Default transmission trouble
I have a 99 cummins with a built 47re tranny and i havent had a prob with it till i changed tranny fluid and now it slips on hard take offs and pulling heavy loads. I used lucas simi synthetic tranny fluid could that be my prob i have a gov pressure sensor high code need help adap
Old Aug 16, 2012 | 01:38 PM
gruffysram's Avatar
Is the Lucas oil rated the same as ATF+4?I would be really easy on it untill you figure out what's causing it.
Old Aug 16, 2012 | 02:47 PM
TheRobenator's Avatar
Is it shifting and slipping when driving? If not, your clutch packs are fine.
Are you sure the fluid is topped off?
Make sure from now on, use Dex/Merc Mix Transmission Fluid.
Did you put a new 2+ clutch torque converter in with the build transmission?
Old Aug 16, 2012 | 05:07 PM
Fuelburner's Avatar
Its got a bd triple disk converter and the only time it slips is hard takeoffs and when i pull my camper up hills
Old Aug 16, 2012 | 08:33 PM
empty wallet's Avatar
What else is done to tranny? just converter? valve body or shift kit? Always run full syn (atf+4) trans fluid, seeing that is what they call for.
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
Trevlar11
Dec 11, 2014 03:30 PM
W350-4x4
Nov 12, 2014 09:35 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
