Opinions wanted, single disc or triple disc?
Old Aug 15, 2012 | 10:24 PM
BarryB's Avatar
Default Opinions wanted, single disc or triple disc?
My truck is pretty much stock, might put a set of injectors in at some point, thinking maybe 60hp range. edge ez. so not alot added power, I am saving for a good convertor. Which brings me to the asking of opinions. I have the funds to go ahead and get a single disc convertor or save lil bit more and get a triple disc? My truck is not a DD, when I do use it. well basically it doesn't get abused. I am doing this upgrade for piece of mind. also, doing the valve body upgrade while I got it out.
Old Aug 15, 2012 | 10:40 PM
skyler1101's Avatar
go big or go home you will become addicted to diesel power as we all do and you will be upgrading in 6 months i had to take 4 clutches out to learn my lesson dont be like me be smart go big your first go around!
Old Aug 15, 2012 | 10:42 PM
You would be fine with one of our single disc converters that are rated to 500hp.
Luke
Old Aug 16, 2012 | 05:25 PM
BarryB's Avatar
My main concern is drivability. With a 3 disc is the shifting going to be pretty aggresive?
Old Aug 16, 2012 | 07:52 PM
mprmn08's Avatar
I wouldn't recommend a triple without a billet input. Just do a single and a good vb. Talk to tim at tre diesel. Hes awesome, really knows his sh..stuff
Old Aug 16, 2012 | 08:10 PM
empty wallet's Avatar
Single's can hold good power, judging by what you want to do, theres no need to go all out. Do the billet actuator piston with the shift kit, and billet band strut and anchor- those are all easy things to do when you have valve body out.
Old Aug 17, 2012 | 09:59 PM
BarryB's Avatar
do you have a link for those parts you mentioned? Sounds interesting, and if I can get to it while I have the valve body out.
Old Aug 22, 2012 | 10:46 AM
lobsterman04's Avatar
I'm still running a single with whats in my sig. Shattered two stock input shafts and turoe the center out of the stock flex plate. A GOOD single will handle what your planning.
