Slight Surging between 1500-1900 rpm
Old Aug 15, 2012 | 03:00 PM
BioHazard2222's Avatar
Default Slight Surging between 1500-1900 rpm
So I got my first Dodge 24v a week ago, switched over from my 7.3 with 330k miles on it…
Anyway, it has been running like a charm up until the other night driving for about an hour and I noticed my pick up slightly surging when I’m either holding a steady between 1500 and 1900rpm or under a little load, like going up a grade holding steady, you can just feel it surging a bit.
Seems to be most noticeable when I’m cruising in 4th gear
I’m not showing any error codes…
Any Ideas?
Old Aug 17, 2012 | 03:10 PM
Nobody?
I read on another forum that it could be related to cruise control, but I tried it last night and it surges both with and without cruise control on.
Any Ideas at all?
Old Aug 17, 2012 | 08:00 PM
empty wallet's Avatar
torque converter locking and unlocking
Old Aug 17, 2012 | 09:02 PM
Thanks but.... that may be if it was an automatic, but mine is a 5speed manual...
Any other ideas?
Old Aug 17, 2012 | 09:15 PM
I didn't read your sig, obviously... probably apps related, check codes? look up apps adjust or reset procedures
Old Aug 17, 2012 | 10:18 PM
No error codes.... Could it be apps with no code? I really don't know...
Thanks again!!!
Old Aug 18, 2012 | 12:11 AM
Zukifreek's Avatar
Mine surged like you were driving in windy conditions. It had no codes. I installed a Timbos APPS and it's perfect now.
Old Aug 18, 2012 | 07:59 AM
Is there some way to test the apps before buying a new one?
Old Aug 19, 2012 | 07:10 PM
So I read on a mother forum that if the problem still exists while using cruise, then it is not the APPS, basicly cruise controll by passes the APPS. Does this sound right?
Any other ideas of what may be causing this?
Old Aug 20, 2012 | 06:02 PM
Zukifreek's Avatar
I don't know about the cruise thing. Mine surged on cruise too until I changed the APPS.
