12 v running issues
Old Aug 14, 2012 | 11:29 PM
cfarley0210's Avatar
Default 12 v running issues
Here is the deal i have a 1997 12v. Pump has been turned up a little. Everything was rinning perfect until i just put head studs in the motor. I did not remove the head to do them just one stud at a time, besides the 6 for the rocker pedistals. I removed the rocker pedistals and had them milled as the instructions said to. I put it all together and now it sounds like there is a valve not closing or something. I can hear a blowing sound through the exhaust sounds like a exhaust leak on a gas rig and is constantly blowing a light cloud of white smoke. I bleed the injectors and adjusted the valves but no change. Is it a possable head gasget problem?
Old Aug 15, 2012 | 01:50 AM
94CTD's Avatar
Could have torn the gasket as the head flexed. I would also shoot out to double check the valve adjustment. Run it with the gf's off and see if something looks outta place. Loosen injection lines one at a time to see if you can figure out which cylinder its coming from.
Old Aug 15, 2012 | 02:16 AM
pukie370's Avatar
did you get rocker arm holders in the dowel pin holders correct? if not you get a pile of soft meatal between which mes up torqe
Old Aug 17, 2012 | 12:33 AM
I will run it tomorrow hopefully if i get time with the valve covers off to see whets goin on. It has to be something simple like a push rod or something.
dwmeehan
Jan 29, 2025 12:13 PM
carid
Diesel Bombers Sponsors
Apr 6, 2015 08:43 AM
octopusmotor
Mar 19, 2015 02:22 PM
carid
Jan 12, 2015 04:32 AM
Polaris04
Dec 1, 2014 08:27 AM
