gear serching? ?
Old Aug 14, 2012 | 10:01 PM
99 cummins build's Avatar
Default gear serching? ?
I have a 99 cummins with a 2001 motor and auto tranny. The motor and tranny as well as the vp44 have 35000 miles on it. It also has a air dog 150 .. here is my problem... between 50 and 58 miles an hoir my truck surges or serches for what gear it needs to be in when its not under a load if i turn the over drive off it does it 10 miles an hour lower than when in over drive ... i have 35 inch tires and just got the spedo recalibrated before i had that done it would serch or surge for gears at 50 to 58 miles an hpur which in actual speed was 60 to 68 miles per hour. Now that the spedo is correct it is still at 50 to 58 miles an hour which is actual speed ... im lost!!! I hear tps i hear tpps i dont know where to go. Thanks for all the help Josh!
Old Aug 14, 2012 | 10:25 PM
RanchhandTCR's Avatar
You can start simple and try to reset your APPS can be your TPS there known to cause problems.
File Type: pdf
Old Aug 14, 2012 | 10:28 PM
Ive un hook both negative cables for about ten mins then hooked them back up keyed it on pushed the pedal to the flood then turned the key off then started the truck but no luck. How much is a tps any way?
Old Aug 14, 2012 | 11:01 PM
On Pure Diesel Power its $219 and $214 at autozone. Im not even gonna look on napa I despise napa, at least where I live but im one of their best customers because they the closet parts house.
Old Aug 15, 2012 | 07:11 AM
So the way i did it shouldve reset the apps then? Thank you for all your help btw
Old Aug 15, 2012 | 07:46 AM
RAW's Avatar
RAW
That is an APPS relearn procedure. A reset will do you more good, followed by a relearn. Search for APPS reset, and you'll find a few procedures.
You can try a lock up switch to see if that eliminates it:
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
If your APPS is gone, Timbo is a popular unit.
Jun 4, 2015 09:30 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:27 AM
rtbcoop
Nov 29, 2014 11:33 PM
Nov 6, 2014 08:10 AM
Spiderman
Oct 6, 2014 09:52 AM
