HP Estimation?
Old Aug 14, 2012 | 11:41 AM
firstgenfreak93's Avatar
Default HP Estimation?
Hey, im shooting for 325 hp for my 91...i plan on doing a fuel pin(stage 2) and 3200 gov. spring along with 4 in turbo back...i have the pump turned up and a cold air intake already on it...will i need injectors to hit that mark...if so how big and will my stock trans hold up or will that need modded as well....i plan on adding custom traction bars as well
Old Aug 14, 2012 | 12:46 PM
moparbubbabt59l's Avatar
Your gona need trans work and a better turbo and at least 5x14s
Sent from my DROIDX using Tapatalk 2
Old Aug 14, 2012 | 01:46 PM
1STGENFARMBOY's Avatar
Intercooled or non, the non injectors will support just about that amount, but thats with more turbo, and like Bubba said you will need a pretty good trans to put down 325 on the dyno.
a guy could have 450hp and with a week trans never see 300 on the dyno.
Old Aug 14, 2012 | 01:55 PM
it is intercooled and what turbo would you suggest like an hx40 or something?
Old Aug 14, 2012 | 02:27 PM
S300g s362 is what most folks will tell you. I run a he351cw and based on my 1/4mile speed im close to 320hp
Old Aug 14, 2012 | 02:28 PM
turbo2332's Avatar
you can make well over 500hp with 5x12's no need for 14's a stocker off a 2nd gen can get you to 350 but an he351 or s300 variant will be a better choice. tc and vb are a must before you start making power. and like stated above non IC injectors are a fuzz bigger and built right stock stick will/should get you in the rehlm of 350hp.
Old Aug 14, 2012 | 02:31 PM
http://www.competitiondiesel.com/for...d.php?t=138923
Old Aug 14, 2012 | 04:05 PM
BC847's Avatar
Really?!
There's a LOT of folks who'd be very interested in that recipe (myself included). Care to share?
Old Aug 14, 2012 | 04:31 PM
turbo2332's Avatar
air man, let her breathe. this is on my 2nd gen not my VE if that is the basis of your argument. clean power is where its at. its much easier to get to big #'s with gobbs of fuel but why? 5x14's are dirty on the street, usable but dirty. my 12's can be to smokey -for me- at times. if you can make 350hp on stockers which are 5x.9's how could there be much argument over 5x12's making over 500? they move PLENTY of fuel for almost all DD situations. just because a truck vomits large amounts of soot into the atmosphere doesnt mean it is tuned properly or has anywhere close to the right mixture of aftermarket items on it to make it efficient.
Old Aug 14, 2012 | 04:33 PM
AHineman's Avatar
I thought the OP was talking about a VE.
