cummins teardown
Old Aug 14, 2012 | 07:44 AM
codycatract's Avatar
Default cummins teardown
Im picking up my 1990 cummins for my ford swap this payday, I am taking head to get machine work but upovoly it only has 80k on it, my question is when I have it all tore down can I micke. The rings to see if they need replaced? If so when I put new rings on if it needs them do I do the same 45 degree ratio as gas engine?
Old Aug 14, 2012 | 08:54 AM
cummin_un_glued's Avatar
FormerVendor
Just replace them tolerance for rings and piston to cylinder on these is very tight. And they go 120*
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old Aug 14, 2012 | 08:05 PM
So put the bottom ring with the gap forward and each one that goes on top do 120 degrees clockwise from that one
Old Aug 14, 2012 | 08:51 PM
RanchhandTCR's Avatar
Yep..
Old Aug 15, 2012 | 07:48 AM
Im not stopping till I have atleast 500 rwh I've seen are rod bolts are those worth there money or does stocks hold up just fine unless your runner like 1500 pounds of torque?
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Dec 18, 2014 03:25 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
