oil pressure
ok so i took my truck to the shop the other week and i was told i need injectors and oil pump. well i replaced my injectors and oil pump last night and when i start the truck the guage takes about 30-40 seconds to come on. i have a code for the guage being bad im thinking it just sending unit just want to see if anyone has had the same problem..
there is a port on top of your oil filter neck. i believe it is a 3/8 port not sure on that number but buy a mechanical guage and screw it into the port and you will have oil pressure right off the filter please note this is right off the filter it wold just be there to show you that you have oil flowing! you can have 60psi there and 0 at the original gauge if all your mains were out. but you can use this port if you just want to make sure it is the gauge not the new pump. this is locatted right next to where your turbo oil line comes out at. i used mine for an oil temp guage.
Durtyd09
Nov 11, 2015 01:43 PM
powerstroke4178
Nov 27, 2014 02:35 PM
