Intermittent a/c
Old Aug 13, 2012 | 06:56 PM
tmk's Avatar
tmk
Default Intermittent a/c
Drive f250 6.0 with 150,000 miles, engine only has 85,000. Since the new engine was installed we replaced 2 injectors, the oil cooler and deleted the EGR. Right before having the work done we noticed the a/c was starting to intermittently blow hot air. The garage was aware but didn't address this issue because was still doing it when we got it back. Took it in and mechanic said its down a pound of freon and that he could see small trickles of leaking oil on my condenser. He tried to show them to me but I couldn't see any differences on surface of condenser. Set me up w/ an appt to replace it for $700. He added freon. Next day I still have the same problem. I call and he tells me I probably already lost the pound he added. My question is, if it's leaking that fast why is it working at all? I've been reading about air gaps and this sounds more like the problem I'm having. Thoughts?
Okay...driving from LA to Phoenix in over 100 degree heat and a/c shuts off for good. Going up long climb engine overheating warning gage goes all the way up suddenly. We pulled over and let it cool down for 5 minutes then crawled up hill and driving at 65 w/o further incidence but no a/c. It has dropped the a/c more when pulling 12,000 lb horse trailer but mechanic that did other fixes said it isn't related to pulling trailer. After being ripped off $1600 on replacing the EMC, I'm not feeling trustworthy. Air coming out of a/c is hotter than desert air. Thank you for sharing your thoughts/ideavs
Old Aug 13, 2012 | 07:31 PM
brentmc's Avatar
I had a similar prob. with my truck and the a/c pump clutch was bad, under full load and w/high(er) rpm's the clutch would over heat and stop working until it cooled down still ran about 800 to have it repaired by ford...
Sent from my ADR6400L using Tapatalk 2
Old Aug 13, 2012 | 07:44 PM
mysterync's Avatar
Is the vacuum pump functioning correctly? It wont cause all of your problems but it can contribute. Sounds like you'll need a qualified tech to take a look. We can bounce ideas all day but until some verification test are completed there's no good way to determine the issue.
Sent from my DROID BIONIC using Tapatalk 2
Old Aug 14, 2012 | 12:17 AM
brentmc's Avatar
I agree to have a qualified tech look at it. That's what I did...
Old Aug 14, 2012 | 02:52 PM
Mdub707's Avatar
Check your coolant level... it's the ONLY time my fan comes on, and it will cause the intermittent A/C too.
Old Aug 14, 2012 | 05:47 PM
EricC's Avatar
the compressor clutch has a shim in it for the air gap on them and when it gets wear on it they get off. You can take the clutch off and take the shim out and see if it works then, may not be your problem but sounds like the ac part not sure on the rest of it.
burndiesel
10
Feb 7, 2023 01:15 AM
Maclain Marsh
Jul 13, 2015 06:23 PM
Jladanyi
Jul 4, 2015 02:43 PM
joldfield
Jun 22, 2015 04:27 PM
CumminsCoalRoller24/7
May 5, 2015 08:55 PM
