1993 charging issue
Old Aug 13, 2012 | 01:19 PM
jdbigblue12v's Avatar
Default 1993 charging issue
my truck started squeaking the other day and i lent my truck to my brother and he ended up putting WD-40 on the belt to get it to stop squeaking but then i think he got into the alternator also because it was still charging fine until i shut the truck off for a half hour and now it only charges when im W.O.T or holding high rev
Old Sep 30, 2012 | 03:50 AM
kcwell27's Avatar
Sounds like belt slipping.
Old Oct 2, 2012 | 02:43 AM
Fluffy nuts's Avatar
yeah u got a slickery belt wd-40? put a new belt on her 35 -40 bucks and leave the wd-40 on the shelf i promise your belt is not gonna rust
Old Oct 2, 2012 | 04:45 AM
12 valve and proud's Avatar
If you want my recommendation I highly recommend going with a Gatorback belt. They are expensive but they don't slip and they have no slipping when it counts which to me is during the rain when the belt can get wet from standing water on the road at 55.
Old Oct 2, 2012 | 10:59 AM
bladeyamaha's Avatar
Alternator is prolly bad, when under load it is almost locking up, sounds like to me, have it tested, take it off and take it to O'Reilly's. Mine totally locked up the electric test motor it was so bad when under a test load.
The Green Gates Fleet Belt is cool looking. It is super heavy duty too.
Last edited by bladeyamaha; Oct 2, 2012 at 10:59 AM. Reason: Automerged Doublepost
Old Oct 5, 2012 | 03:59 PM
no belt wasnt slipping i replaced the belt with gator back and it still didnt charge but turned out to be a bad pcm voltage regulator so i wired up an external and the bi*ch runs mint and charges
Dec 10, 2019 10:10 AM
Diesel_Daddy6.0
Sep 23, 2015 03:12 AM
Cummins_Power_13
Feb 4, 2015 09:55 AM
Oct 23, 2014 08:10 AM
hemiheath
Oct 15, 2014 11:49 AM
