2004 injector wire harness
Old Aug 12, 2012 | 08:27 PM
EricC's Avatar
Default 2004 injector wire harness
i have a 2004 f250 will a injector wire harness off of a 2003 fit the 2004? both are 6.0. Also do i need a special tool to remove the clips from the injectors? thanks
Old Aug 12, 2012 | 08:41 PM
bobfbigman's Avatar
You can use a pair of needlenose to pull the clips out, real easy, you can use your fingers to pull them out if you can get them in there. I forget if the ICP sensor is on the injector harness or not, anyway the later 04 has the ICP on the pass. sid valve cover and the early 04 and 03 have the ICP sensor on the backside of motor.
Old Aug 12, 2012 | 09:40 PM
EricC's Avatar
as far as i can tell the only plugs on it are the injectors, could be wrong but there are only 8 plugs plus the one that goes to ficm, just was not sure if the plugs where the same on the injectors
Old Aug 12, 2012 | 10:58 PM
bobfbigman's Avatar
Yes, all the injector plugs and FICm plug ends are the same. Be carefull with the little clips, they can fly off once they are pulled partially out, that is why I use needle-nose plyers on them, I always put them in my ashtray until I am ready to reinstall them so They don't go missing on me.
Old Aug 13, 2012 | 10:31 AM
Mdub707's Avatar
You find an issue with your wiring harness Eric, or just trying it to eliminate possibilities?
The clips are pretty easy to do on the injectors. Just make sure when you put them back they are fully seated. Also Bob is right, watch those clips sometimes they shoot off like a rocket.
Old Aug 13, 2012 | 09:37 PM
EricC's Avatar
Yeah I think it's te plugs they are broke all to hell. I orders a used one on eBay for 75$ off of a 03. In really good shape
Hey mike is there any better air filter than the stock one? Its almost time to replace mine and just wondering
Old Aug 14, 2012 | 12:15 AM
Kneedragger79's Avatar
I realize you were asking Mike but the answer is simple: The stock filter can me a pta to remove but it holds more dirt *filters better & longer* than any aftermarket filter.
Old Aug 14, 2012 | 02:55 PM
Mdub707's Avatar
For pure filtration properties, he's right, the stocker is pretty much the best out there. It will still support a decent amount of power too. I ended up going with an AFE stage 1 kit (very similar to stock) with a proguard 7 filter. I like the dry filters ONLY for turbo motors, or anything with an MAF.
Old Aug 20, 2012 | 10:23 PM
EricC's Avatar
Got the wires changed today. like a new truck now!
Old Aug 21, 2012 | 07:52 AM
Mdub707's Avatar
Eric, for giggles, can you re-test the FICM and see what the voltages are now? I'd just like to know for curiosity sake. Glad to hear that fixed it though!
