Hissing sound
Old Aug 12, 2012 | 08:04 PM
danbar300's Avatar
Default Hissing sound
Just happened tonight coming home. I had to hit the brakes for some lane changer in front of me. After that a hissing noise started under the dash. Every time i go to or turn the wheel,or brake the hissing goes away, any suggestions?
Old Aug 12, 2012 | 09:13 PM
knowlzy1824's Avatar
Been there, believe it's a hydroboost problem. When I had the hissing sound in my steering column except for when I was turning or on the brakes I had split one of the hydraulic lines coming off the firewall directly in front of the driver in the engine compartment. Check that out, jiggle the lines to see if they stop or get quieter/louder and check everything that they go to. If this doesn't help I tried, the lines from the dealer were crazy expensive but only cost me around $20-$30 at my local Bobcat shop. Good luck and if you do have to remove these lines be cautious and a good set of line wrenches will come in handy.
Old Aug 14, 2012 | 09:05 PM
danbar300's Avatar
WELL TODAY I TOOK THE HYDROLIC LINES OFF AND BLEW THEM WITH AIR PUT THEM BACK ON, AND NO LUCK STILL HISSING
GT_Eleanor
Aug 24, 2015 12:11 AM
Timglow546
8
Jun 3, 2015 10:13 PM
JoeRamsey26
May 29, 2015 06:40 PM
mpmcbride42
Apr 7, 2015 08:28 PM
xj_crawler
Dec 4, 2014 09:09 PM
