possible tranny problem?
Old Aug 12, 2012 | 09:45 PM
codyawise's Avatar
Default possible tranny problem?
i have 3.55 gears in my truck and whenever i get around 45-55mph the tranny tries to downshift and then it'll go right back. i figured out that this really only happens whenever the trans temp is over 170. so my question is, is there anything wrong with my tranny, anything i can do to keep my trans temp lower?
any help will do thanks
any ideas on what it could be?
Old Aug 13, 2012 | 12:39 PM
globalwarmingcontributor's Avatar
well, ill be the first one to answer.. im sure other guys will chime in.. could be a TC lockup switch.. theres also an APPS noise isolator that BD diesel sells. it fixes RF interference from the APPS circuit, which could be causing your issue.. heres a link to what im talking about.. i think they run like 25 bucks or something like that.. may be a good try.. i think ive seen them on ebay. hope this helps
BD Power - Product: APPS Noise Isolator
Old Aug 13, 2012 | 12:41 PM
RAW's Avatar
RAW
170 sounds fine. Trans oil goes from the trans to a heat exchanger. Engine coolant warms the trans oil (upwards of 190*), then it is sent to the cooler at the front to cool down a bit.
Almost sounds like a torque converter lock up issue. Any codes?
Old Aug 13, 2012 | 05:10 PM
codyawise's Avatar
I have not checked for any codes. What do yall mean by it could be a lockup switch? What exactly does a lockup switch do? Is it better for it to be locked or unlocked?
Old Aug 13, 2012 | 05:44 PM
RAW's Avatar
RAW
Have a look at this:
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
Old Aug 14, 2012 | 10:09 AM
codyawise's Avatar
so you guys think that noise issolator could help out my problem?
Old Aug 14, 2012 | 11:16 AM
RAW's Avatar
RAW
It could. The rewire is a lot cheaper, and may fix the problem. I would start with that. You may also want to do an APPS reset, and relearn. If you search this site for those two procedures, you'll find a write up.
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
tim12valve
9
Apr 21, 2015 05:51 PM
wilki
Feb 12, 2015 09:04 AM
Ol' RED!
Dec 11, 2014 10:00 AM
