Turbo housing horsepower gains
Old Aug 9, 2012 | 04:21 PM
Cow tipper's Avatar
Default Turbo housing horsepower gains
How much horsepower will I gain by putting a 16cm turbine housing on my truck?
Old Aug 9, 2012 | 08:27 PM
turbo2332's Avatar
over all none but you will make power sooner so that you can use it more effectivly. the 16cm housing is a good upgrade for the stock h1c. if you are going to do something to the h1c i would go for an hx35 or wh1c 12cm gated housing that came on all the 2nd gens and swap to that. you will need a new flange for you down pipe. then it would be a 54/60/12.
Old Aug 10, 2012 | 12:17 PM
Cow tipper's Avatar
Sweet man thanks
Which one is better for the stock h1c? The 14 cm housing or the 16?
Last edited by Cow tipper; Aug 10, 2012 at 12:17 PM. Reason: Automerged Doublepost
Old Aug 10, 2012 | 12:19 PM
turbo2332's Avatar
you can get into excessive drive pressure issues with non gated housings. the 14 will spool faster for sure. if your truck is nearly stock with no plans on more fuel than you should be fine with a 14.
Old Aug 10, 2012 | 04:35 PM
Cow tipper's Avatar
I have a fuel pin governor spring and I'm going to probably just put stage 1 injectors so I won't have to upgrade the turbo
Old Aug 10, 2012 | 04:51 PM
turbo2332's Avatar
is your truck intercooled? if it is i would just look at putting an hx or wh1c on it and be done. if yours insnt intercooled it is more of a pain to switch turboes. then i would go with a smaller housing.
sak240
Oct 1, 2015 04:07 PM
D-350 dually
Apr 11, 2015 11:38 PM
MrCat4974
Mar 25, 2015 08:13 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
