3200 govener spring
Old Aug 9, 2012 | 01:56 PM
willyslick's Avatar
Default 3200 govener spring
Help,just installed 3200 govener spring.now when i start goes to full throttle.
Have to turn key off fast.
Whats going on?
Old Aug 9, 2012 | 04:40 PM
Cow tipper's Avatar
Your throttle index is off you have to Adjust the throttle indexing.
This is what it's supposed to look like
Ve pump full throttle - Dodge Cummins Diesel Forum
Old Aug 9, 2012 | 04:52 PM
92betsy's Avatar
^^^ This.
Old Aug 10, 2012 | 12:24 PM
willyslick's Avatar
got it running,now throttle hanginging,takes too long to spool down after pressing throttle.
do i need to adjust index again?
already checked tps voltage and is good.
i backed down on fuel adjustment also and seemed to help.
Old Sep 5, 2012 | 10:19 AM
t-bone117yamaha's Avatar
does your truck have cruise control? when i replaced my fuel pin i didnt get the cruise control lined up right when i put it back on and it made my throttle stick and spool down slowly so if so that may just be an idea. you would be able to feel the ressistance if you play with the throttle arm under the hood.
Old Sep 17, 2012 | 03:34 PM
willyslick's Avatar
NOW I THINK HEAD GASKET BLOWN
OIL FOAMY AND GREEN MILKSHAKE
Yes i have cruise.ill check it out.
Last edited by willyslick; Sep 17, 2012 at 03:34 PM. Reason: Automerged Doublepost
Old Oct 11, 2012 | 11:42 AM
willyslick's Avatar
ok,reindexed throttle.now it idles great but will hang and tend to run away at only slight movements of throttle.
tried turning fuel screw back but when its almost runs normal the engine stalls and wont start until i turn up fuel screw again.idle at 750rpm
what gives,running out of patience
Old Oct 11, 2012 | 09:47 PM
lodal cummins's Avatar
***** my man take a time out and know we have all been there a time or two when stuff does not go well. Start over! That vid I told ya about follow it to a tee as your doing the work. Make sure the lever next to the top hat or pin the spring goes through is going toward cab. The fuel screw is very touchy in terms of you can't just turn it in. Go in half turns and start truck to get the right idle. Where is the green milkshake comming from????
Sorry I say 1/4 turns instead.
Last edited by lodal cummins; Oct 11, 2012 at 09:47 PM. Reason: Automerged Doublepost
Old Oct 11, 2012 | 11:10 PM
willyslick's Avatar
i did it like the video.didnt move any lever. fuel screw wasnt that touchy whin i originally turned up the pump.
i added bigger injectors and new custom turbo when i did govener spring all at same time.
cant figure this one out.
now im running without connecting throttle linkage anb rod.also tps not installed.i was told on this truck tps only controls shift fron 3 to 4 on transmision.is that correct?
Old Oct 11, 2012 | 11:43 PM
Ok so truck runs with no linkage correct? If you turn index shaft by hand is it smooth? As far as tps I'm no 100 percent sure as mine is a 5 speed but on my 96 auto 1-3 is hydralic and tps controls 4 and o/d.
Did you see the lever in that vid and ya sure it's where it needs to be?
Last edited by lodal cummins; Oct 11, 2012 at 11:43 PM. Reason: Automerged Doublepost
