Newb with rear axle leak
Old Aug 9, 2012 | 11:18 AM
muzzfactor's Avatar
Default Newb with rear axle leak
Hey guys, I'm new here and new to the "Cummins" world. I've got a 2003 3500 4x4 SRW and I have gear oil coming out the end of my passenger side rear axle. Is this a very hard job? Anything I should be aware of before tearing this thing apart? Any insight is greatly appreciated.
Old Aug 9, 2012 | 12:39 PM
TheRobenator's Avatar
Does this have a heavy duty style rear end? I'd hope so, If so, you take the 8 or so bolts out of the cap that is at the end of you axle and start removing the bearings and such, then replace that seal that is where your axel slides through.
Old Aug 9, 2012 | 12:46 PM
muzzfactor's Avatar
Cool, that definitely sounds like something I can handle. Thanks.
Old Aug 9, 2012 | 12:49 PM
No Problem!!
We have alldata at our shop so if you need some help and kind find out how something comes out, just pm me and I'll try to help you out.
Last edited by TheRobenator; Aug 9, 2012 at 12:49 PM. Reason: Automerged Doublepost
Old Aug 9, 2012 | 05:32 PM
c farmer's Avatar
You have to remove the hub and the seal is in the back side of the hub. The Robenator is correct, I just wanted to say that the seal is in the hub not the axle tube.
Old Aug 10, 2012 | 08:25 AM
steved's Avatar
Depends if its the hub seal or the gasket between the hub and axleshaft...the way he describes it, it sounds like the axleshaft is leaking, not the wheel/hub seal.
Old Aug 10, 2012 | 09:20 AM
muzzfactor's Avatar
Well I actually got pretty deep into it last night and it is actually the hub seal that has been leaking and it looks like the bearings are shot. It looked like real fine steel wool was inbedded in the bearings so it looks like that are getting replaced this evening.
Machinist
Jun 23, 2015 06:57 AM
southern dieselnorth zip
May 18, 2015 01:02 AM
ash23k
Dec 30, 2014 08:31 PM
Dec 19, 2014 02:30 PM
natenel1
Oct 26, 2014 03:09 AM
